I am not really aiming for cold air. I am aiming to stop taking in water when I dip the nose into water holes. I am sacrificing one thing for another. Water being the greater of the 2 evils.
But I will likely check IAT out of curiosity.
The actual choice in hood vent location came to me from reading the linked post.
Hood Vent Location Link
Not getting cool air is one thing - getting hot air is quite another. If your IAT's get up there the computer will pull timing to avoid detonation. If you think your 4.0 is underpowered now...
Note: This is definitely the way it works in the Hemi. In my case when I had the air intake temporarily in the same general location as your proposed location - I dropped 50 ponies on the dyno. Been a long time since I worked on a stock 4.0, but I believe it works the same way in this regard. Someone correct me if this is not the case.
I have seen that and its in the wheel house. I just want to toss around a few other ideas before jumping into the cowling. I have tossed around a few ideas with the Windstar filter under the hood and I may try them out depending on how this goes.
A cowl intake is a good way to go. You also don't have to worry about rain getting in there if it is set up correctly.
Glad to see you exploring options, Unique.
