Already have a new one installed on the new pump.Do yourself a favor and replace that inlet pipe as well, she looks to be rusting out from the inside.
https://www.amazon.com/gp/product/B001C6JCU0?tag=wranglerorg-20
Well, crap. They won't be here before I need it back together. Probably will do that this spring when I change the heater core.Even better, install an aluminum NPT-to- 5/8” barb fitting. This will make future replacements much easier. I learned of this option from others.
I believe this is what I installed.
Join it to some extended 5/8” heater hose with this Barb fitting.
Got the last fender on. I just have to modify my RockHard sliders to fit around the front fenders. I'm very impressed with his the first and finish is on these fenders. The only thing I had to do was bend the edge at the upper shock mount to clear the stud. Other than that, everything fit perfectly.
Also got the water pump off and ready for a new one tomorrow afternoon. This looks to be the original one; replacing it with a NOS Mopar one.
Yes they are. Thank him for his service. Hopefully he’s working as a government contractor now?
IIRCI know that feeling all too well…needing the same fittings delayed a drive to CA this past summer.
I chose aluminum over stainless steel or brass fittings to avoid issues with galvanic corrosion.
I failed to mention, don’t forget to get some clamps. Sorry about that. According to my purchases, these might be what I’m using.
yesterday took the stock wheels i painted off the jeep and bolted on the Hubs i painted to match the jeeps paint
we've got 4inches of white stuff coming this morning so im gonna be playing in the snow
IIRC
If you're using GO5 HOAT coolant you shouldn't have that problem
FIGHTS
HYBRID ORGANIC ACID TECHNOLOGY FIGHTS RUST, SCALE & CORROSION while protecting all cooling system metals (including aluminum)
https://shop.valvolineglobal.com/pr...Vo-odlJLUT8IRCc50Y9rdvR62tI83JOge0PuJh7Wj_Xl_
I guess since I haven't had a need to modify things in my cooling system, I'll probably never have to worry about that. But it's not just Valvoline's marketing that makes the claim that it stops corrosion in cooling systems with dissimilar metals.I only run G05, but it doesn't eliminate rust or galvanic corrosion in our rigs with an iron block.
Even with distilled water and G05 coolant, electrolysis will take place because the rust on the surfaces of the iron block contains charged particles of iron that enters the solution (creating an electrolyte) and reacts with the dissimilarly composed radiator, water pump, and heater core.
This means that fastening an incompatible fitting to aluminum water pump will likely result in galvanic corrosion. I prefer to employ the minimal effort to prevent that from happening.
Do you trust the marketing that you highlighted above enough to install incompatible fittings simply because you are using G05?
Drove BB to work today, runs great and drives great.
New control arms are quiet and no vibes at highway speed!!
We will see how the Metalcloak arms hold up over the next year!!!!
Probably try and hit Coalmont OHV Park and Estill Forks and maybe Stoney Lonesome after the first of the year just to see how they do.
Must be a Hobbit fan.
It could be a bad ECM. The voltage regulator is built into the ECM.
