Even better, install an aluminum NPT-to- 5/8” barb fitting. This will make future replacements much easier. I learned of this option from others.
I believe this is what I installed.
Join it to some extended 5/8” heater hose with this Barb fitting.
Well, crap. They won't be here before I need it back together. Probably will do that this spring when I change the heater core.
I know that feeling all too well…needing the same fittings delayed a drive to CA this past summer.
I chose aluminum over stainless steel or brass fittings to avoid issues with galvanic corrosion.
I failed to mention, don’t forget to get some clamps. Sorry about that. According to my purchases, these might be what I’m using.
Reactions: mjonesjr84
I cleaned up burrs on carrier housing, degreased with wd40 specialist degreaser not dry out seals. Put back together with gear oil. Going to leave old carrier bearings on for pinion set up. Did get Vevor clam shell puller. Yoke puller should be here soon. I tried drift pin method again today to remove pinion, no avail.
Carrier bearings and new ring bolts coming in early this week. Yes….I am addicted to tools.
Got the last fender on. I just have to modify my RockHard sliders to fit around the front fenders. I'm very impressed with his the first and finish is on these fenders. The only thing I had to do was bend the edge at the upper shock mount to clear the stud. Other than that, everything fit perfectly.
Also got the water pump off and ready for a new one tomorrow afternoon. This looks to be the original one; replacing it with a NOS Mopar one.
Are those horns OE?
Drove BB to work today, runs great and drives great.
New control arms are quiet and no vibes at highway speed!!
We will see how the Metalcloak arms hold up over the next year!!!!
Probably try and hit Coalmont OHV Park and Estill Forks and maybe Stoney Lonesome after the first of the year just to see how they do.
Yes they are. Thank him for his service. Hopefully he’s working as a government contractor now?
Thank you. Same to your son.
Yes, I was worried when he decided to get out in 2020 but he had a contract electrician job lined up within a week. He was an electricians mate. He’s since switch jobs again and has a GS level job.
IIRC
If you're using GO5 HOAT coolant you shouldn't have that problem
FIGHTS
HYBRID ORGANIC ACID TECHNOLOGY FIGHTS RUST, SCALE & CORROSION while protecting all cooling system metals (including aluminum)
https://shop.valvolineglobal.com/pr...Vo-odlJLUT8IRCc50Y9rdvR62tI83JOge0PuJh7Wj_Xl_
IIRC
FIGHTS
I only run G05, but it doesn't eliminate rust or galvanic corrosion in our rigs with an iron block.
Even with distilled water and G05 coolant, electrolysis will take place because the rust on the surfaces of the iron block contains charged particles of iron that enters the solution (creating an electrolyte) and reacts with the dissimilarly composed radiator, water pump, and heater core.
This means that fastening an incompatible fitting to the aluminum water pump will likely result in galvanic corrosion. I prefer to employ the minimal effort to prevent that from happening.
Do you trust the marketing that you highlighted above enough to install incompatible fittings simply because you are using G05?
This means that fastening an incompatible fitting to aluminum water pump will likely result in galvanic corrosion. I prefer to employ the minimal effort to prevent that from happening.
I guess since I haven't had a need to modify things in my cooling system, I'll probably never have to worry about that. But it's not just Valvoline's marketing that makes the claim that it stops corrosion in cooling systems with dissimilar metals.
Now that may not account for physically attaching dissimilar metals. So... yep it's definitely best to use similar metals.
Reactions: John Cooper
Go ahead and order a set of the snap ring pliers with the interchangable ends. If you wheel regularly those joints don't last as long. But they are easy to replace with the right tools.
Also when MetalCloak has a sale stock up on replacement bushings. That is what I did
It doesn't stop corrosion...nor does it make that claim.
If the label said "slows corrosion down better than many other alternative options" you might not buy it. Instead, they use words like "fights" and "protects", which provides comfort through carefully executed marketing.
You interpreted that label to mean G05 "stops corrosion" when it does not (for reasons that have already bean explained). You probably see right through marketing in other instances that falls in the "mere puffery" category in sales, and the marketing you highlighted from Valvoline is no different. They simply dumbed it down for the average consumer.
Maybe you should put some sacrificial zincs on your rudder...
