I vaguely remember reading something about using adjustable control arms to help center the axle and I got to thinking every time I need to remove the trackbars, it is a huge PITA to re-install them. So I am wondering if my control arms are adjusted in a manner that is causing a bind when centered with the track bar at ride height. Every time I go to install I need to use a lot of force, especially the rear where I have broken a few 1in wide ratchet straps and got a 3in wide ratchet strap specifically to center the rear. I usually need to pull the front about 3/8" and the rear 1-1/4". Is there something to using the adjustability of my control arms to help center the axle so installing the track bar is easier and causing less bind when at ride height? I have double adjustable control arms all around and adjustable trackbars front and rear that are adjusted to center.
