I wonder what the difference is between a 3.6 & Hellcat is price wise?
DIY vs them installing it? 22k seems insane to me but I guess that's cos I'm a DIYer.
Friends 2GR swap in MR2 was 18k I guess
Friends 2GR swap in MR2 was 18k I guess![]()
We know your ass cheeks couldn't pass a dollar bill you're so CHEAP....
This is into a JK/JL price but a TJ/LJ would be comparable I'd guess... But if you tried to source a Hellcat take out I'd guess you're at $12K minimum & you'd need a 4x4 8HP to go behind it since the Challenger won't work.
I so am. I have a friend and we always joke "ya don't pay off a house early spending money for X!!"
Holy moly that is expensive. They need to put a "spoiler" over those prices, no POORS allowed!!!
The 2012-2014 3.6L V6 Pentastar engines had many issues with their heads which required several redesigns.
The head PN double letter identifier (revision) went from AA to AD before the problems were resolved.
When sourcing a Pentastar engine to install verify the engine is a 2014 or newer so you are not getting an engine with the head problems.
The 3.6 is not half bad. It was built for fleet use and it has been out long enough to have a very proven track record. Itās one of the last port injection engines that donāt get all gummy. I wonder how well the 3.6 and 8 speed packages in the tj. If it would allow for proper front suspension uptravel, a tummy tuck at least as good as stock drivetrain with a savvy skid, and a reasonable rear driveshaft length I think it would be an extremely compelling option.
Lots of tech info on the Allpar website, but couldn't find the actual weight of the 3.6L Pentastar. As an earlier poster stated . . . a 4.6L stroker with aluminum head . . . that sounds very interesting.
As to the color of my text . . . it, and many other color options are available to all on this fine website.
The 3.6-liter Pentastar V6 engine weighs around 326 pounds (148 kg) depending on the application.
Here's a more detailed breakdown:
- Weight: The engine weighs approximately 326 pounds (148 kg).
- Design: FCA used a thin-wall strategy to reduce the nominal thickness of certain die-cast components, without compromising NVH (noise, vibration, and harshness).
- Application Specific: The weight can vary slightly depending on the specific vehicle application.
- Comparison to Previous Model: The new Pentastar is 4 pounds lighter than the previous 3.6-liter Pentastar, despite the addition of new components weighing 13 pounds.
- Engine Type: The 3.6-liter Pentastar engine is a 60-degree V6 engine
- Construction: It is constructed with a high-pressure, die cast aluminum block fitted with cast iron bore liners and aluminum cylinder heads.
I can think of a V6 I'd like to have in my Jeep. Not sure that the front suspension can be beefed up enough to support it though.![]()
Pentastar V6 . . . Has anyone done this re-power to a TJ?
Wondering the pro's & con's of a transplant into a 5sp. TJ.
Keep your TJ 'all Jeep' . . .
Thoughts . . .
You want the blown on thats sitting in my jku? these motors are absolute trash garbage.
I see endless problems on a Gladiator forum I look at. They have real valve train issues , but at least they are expensive . Sorry about your JKU , bummer !
the oil cooler has serious issues on them. its so ridiculous and if you dont catch it in time...blown motor. i have a aev jku350 that i paid $90k for and cant drive it lol. sits in a storage lot. my swap will be a om606 from mercedes (i work for them) with a dieselpunk intake plenum and pump.
I believe the company that's doing the V-6 swap decided to reuse the giant pile of engines they were removing from JKs, JLs, and JTs and see if they could sell em.
Hadn't thought about that.... But good point.... They'll sell you some Dana 44 Rubicon axles too from a JK/JL/JT...
