Nobody anticipated the depth of the hole on the rear passenger tire.
There’s a good lesson here to learn about up travel and why you want more of it. That front passenger tire can articulate up into the wheel well until you either hit your bump stops or your shocks bottom out and the goal is to have your shock be the limiter and so you basically want your shock to soft bottom out. At that point you have no more uptravel and any more movement will cause the body to roll. And that’s what happened. I reached maximum uptravel which is about 5 1/2 inches on my rig and then the body gets upset and it happens quick. If you have more uptravel, then you can gain more articulation for longer which will enable you to stay stable and the body to be happy.
This is why a low center of gravity build would’ve done even worse.
