Jeep idles at 1300-1400 during warmup and settles down to 1100.
As I drive And press the clutch the idle rises from 2000 to 2500 +, sometimes fluctuating and dropping down under 1000.
When I kill the ignition it sounds off as it dies.
The replacement grommet had a slightly larger hole, but the new PCV valve fit correctly. I used the old tube to connect to the new PCV Valve. I assume it has a good seal, but I’m assuming. Can anyone help? I thought I might take the new one off and re-install the old one or replace the short tube as it exits the PCV Valve.
