Hey guys, first time poster here. Bought my '06 4.0 (auto trans) a little over a year ago. Had a lit CEL for a faulty o2 sensor when I bought it.
Recently the CEL has begun flashing, but only at idle once up to operating temp (wont flash at idle from cold start). It also starts to smell like its running very rich, which is 100% the case from the DTC's its showing.
Only recently did I have my first misfire from this. It was after a long wait at a red light. Once I began driving it sputtered some, but then was fine right after. It also seems my fuel mileage is terrible, as to be expected. Other than that, when driving at normal speed she seems totally fine. Idle is when it gets rough and CEL flashes/rich smell.
Just want some insight on what to attack on this first? all o2 sensors? Are my pre-cats bad? (This is a cali - 4 o2 sensor TJ) Camshaft sensor, coolant temp sensor, or even the dreaded failing PCM? This is my first Jeep so also learning all of this as I go.
One more note, I may have some type of ground issue, as months ago she wouldn't start, but once cleaning the ground terminal it was fine, but randomly the ground seems like it disconnects, as my radio resets, and the CEL goes away for a bit.
Here are the codes its showing.
P0138 - O2 Sensor Circuit High - Bank 1, Sensor 2
P0301 - Cylinder 1 Misfire
P0171 - System too lean bank 1
P0172 - System too Rich bank 1
P0174 - System too lean Bank 2
P0344 - Camshaft position sensor A circuit intermittent - Bank 1 or single sensor
Any help is greatly appreciated.
