Case in point the Ford Ecoboost oil cooler mod. I looked it over but didn't see any data supporting it's installation other than claims of improved fuel mileage...which might have come from other mods like a tune, ceramic coating the exhaust and intake and an electric fan.
Nonetheless I pressed on. I installed the oil cooler and I installed a glowshift oil pressure and temperature sensor.
I've tracked enough data at this point to know the mod does more oil heating than cooling...I haven't removed it yet because I'm still researching whether or not that's a good thing or bad...but absolutely zero change in fuel mileage.
I saw a GM study that showed piston wear increased as coolant temps (and oil temps) dropped.
It showed that coolant temps at 240 was better than 230, which was much better than 210, which was better than 200 and so on.
From that info, I assumed the 195 thermo stat might be a balance to get the coolant and oil temps up to reduce wear but low enough to not cause other problems like blown head gaskets, etc.
I don’t know if that’s that case, but that’s where my head is currently at on it.
All that to say maybe adding the cooler/heater helps reduce engine wear? I’m in no position to have a planted stance, but it’s something to possibly consider as you evaluate this.
As long as your coolant temps aren't over heating, I can’t think of why having the oil heat up sooner and remain a bit higher (more towards your ECTs) would be a bad thing.
