From my understanding the point of out-boarding the rear is to raise the mounting point of the shock to fit a longer travel shock (12inch travel), move the mounting point closer to the tire for more control, and go with a tunable shock.
So with the front your gain in shock travel is minimal, the mounting is already out-boarded though you could move the axle side about an inch or so further out, and lastly the option for a tunable shocks.
I have found that you can get tunable foxes (with cd tuning knobs) for the factory mounting location that are 10inch travel with a 15.1inch compressed length.
https://accutuneoffroad.com/product...-reservoir-10-1-3-4-5-2-3-5-lift-cd-adjuster/
That option that gives my set up exactly 5inch of up travel and 5 down up front, 4inch till I touch the Currie bump with the expectation of 1inch till the shock shaft is 0.
So for those that have outboarded the front, is the work to package it worth it to get 1inch more of travel which would only be downtravel or are the options for tunable shocks different/better that would be pair with a rear outboard better?
