Is my TJ lifted?
With aftermarket lowers it pretty much tells me a lift is present correct?
Maybe when they were new. Those are not nice arms, which may mean the accompanying not nice springs have sagged over time. It doesn't matter what they used to be. The tape measure tells you what they are right now.
Im not sure how in the world the 35s are on there with no lift
35s will physically fit in the hole. That doesn't mean that they will allow the Jeep to perform as it ought to.
My advice is that any modification should always maintain the stock amounts of suspension travel. ~4" up/~4" down. You start to lose that at 31s.
This is where learning how to cycle the suspension is a very valuable to let to help you understand what is going on down there.
I just took this photo. The previous owner did a terrible job with paint:(
When the be 3.75" lift gets installed, does this include an SYE/double cardan rear drive shaft?
Which lift?
Got it. That is essentially a ~2.5" spring lift with a small body lift. Very similar to the Zone 4.25 combo lift, but a bit less lift. It's a good strategy. A motor mount lift may be something to consider. It helps with the rear driveshaft and it makes parts of the body lift easier.
The shocks may be the weak point in that they will ride rougher than is necessary.
Don't fall victim to the "Jeep thing" mentality. It doesn't need to ride and handle like crap.
Reactions: The Goblin
I may go with the zone and fox shocks. Its a bit more but who said jeeps were cheap? Lol
Zone 4.25 combo with Rancho rs5000x shocks would be my recommendation.
I might even go so far as to use all stock control arms, until you can go with decent adjustables.
Much better. Your front rotors look pitted badly in that pic. The paint job looks like a quickie to cover up rust before selling.
Based on the pic and the fact you say it has 35's I am going to say yes you have a lift.
Here is a pic of my TJ when I put on 31's a long time ago
Hey man just ran across this thread and saw you had 31 claws on your TJ and that’s what I’m wanting to run. Did you have a small lift or what? Could I get a few more pics of when it looked like that and some details? Haha sorry for fan-girling
