Tworley build
Yesterday we installed most of the arms and greased the JJs. I was setting lengths and found the rear lowers were an inch too long, meaning I got the LJ arms. Called Gerald and he said ship them back and he'll cover shipping for the return and new set. All this on a Saturday/Sunday.
The front axle got installed, squared and centered and checked cleareances. The currie trackbar barely kisses the diff cover at full bump. The drag link was put in a press for a bend to clear the hydro. The tie rod was flipped with a different knuckle. Pulled everything back off and painted the axle.
Today for the front, we installed currie bumpstops, moved the ram assist bracket slightly, and cycled the axle more.
At this point, brakes are ready to go back on and everything torqued to spec for the front.
Only pictures from today. I had to get new hydraulic brake hose from an 03 TJ. The 97 hoses are crimped.
At this point, all thats left to do is...
-build the oil pan skid mount
-Torque the front to spec
-Install/cycle the rear axle
-Modify the frame side brake line
-Exhaust
So close. This has been 5 solid days of work.
The torque boxes, savvy body lift and body mounts will be done at a later date.
View attachment 631808View attachment 631809View attachment 631810
-Exhaust
Sounds like an opportunity for a rear stretch!
Nice work.
My socioeconomic class is all wrong for those benefits.... that and the work van has a name,phone number and contactor ID in large block lettering on the side.
For 5$ i bet I could get a tweeker to grab it though
I'll give you $10+shipping
Front track bar needs torqued, the exhaust routed and built, the rear bumpstops installed and the oil pan skid bracket needs fab'd. One more solid day of work I think.
I found a pretty good muffler combo that fits well under a TJ with a midarm. It has a nice tone, and is not overly loud. Nice burble under decel, and doesn't drone. It also tucks up pretty nice as to not get hung up on rocks.
The converter is in its factory location and I shortened the pipe in between.
Assembly is required :)
Street Max SM65110 Shortie Oval Muffler 2.5 Offset/Center to a 2.5" AERO Exhaust TR254 Stainless Steel Resonator.
THanks! Ill keep that one in mind. I have a Hush Thrush 17633 now. It will require a little bit of massaging to fit over the savvy cross-member, and the cat will need to be moved forward towards the engine, but I think its doable.
Reactions: Irun and Wildman
Wait, what happened here? You evict him?
