It shouldn’t really ever be difficult to pull out of 4H into 2H, because it’s literally just sliding a collar off of some teeth.
I feel like you have a t-case disassembly ahead of you.
There is also the possibility that somebody went in there before and forgot to put the snap ring on the main shaft that pulls the main shaft rearward, which could keep it engaged in the collar even when in 2WD.
But the fact that the shifter won’t even go into 2WD makes me think you have a bigger issue internally than the snap ring.
Is there anything else you could suggest I do before removing the TC and proceeding to disassembly? The lever is really stuck..
Should I just buy a new transfer case or should I take it apart and rebuild it? This is so strange considering that 4WD was never used. What do you think it could be if bigger than the snap ring issue?
