I think technically it’s right, from what I’ve read it sounds like Rancho measurements are a little weird and the “matching” size is usually a little too long. And the Zone combo lift is a 3” suspension lift, the rest of the lift comes from the BL and MML. So I would assume the 2.5” shock is right, but what do I know (not that much lol)
yeah you're right there, didn't process the "combo" part of the combo 4.25" lift so that would be the right PN
One thing that does look a bit suspect is this spot on the shaft though. It will chew the seals pretty quick if its actually as rough as it looks. should be a polished chrome surface for good sealing and minimal wear on the seal.
