I need help.. I have a 1997 jeep TJ sport auto. I just got my transmission back from rebuild shop. Transmission will NOT shift out of first gear. Again this is an automatic jeep. When I manually shift it to second gear, it shifts absolutely great, no hard shifting no delayed shifting, it won’t shift out of first on its own, reverse and first does feel like it has a delay in power maybe limp mode.. I’ve checked fluid level with engine on and in neutral. Fluid level is fine. I’m either thinking it’s my transmission shift solenoid or throttle/kickdown cable adjustment. Allthough the throttle and kick down cable seems to have properly adjusted slack.i don’t have a multi meter to test TCC solenoid. But BEFOREI had transmission rebuild it did shift on its own, but was very delayed and hard shifting. After rebuild. Won’t shift by itself at all. But shifts manually perfectly.
EDIT: I have fixed the transmission not wanting to shift on its own by tightening the band screw on the transmission, took it for a test ride and it shifts good on its own now perfectly. Buttt I now have a 50% power loss it’s pretty bad and it feels like the jeep sometimes stays in 2nd when coming to a stop because of how hard I have to press on gas and RPS are screaming before it gets going. Feels under powered.
