Transmission shift point problem
Old Iron
N/A
Hey everyone, I have a 2002 Jeep TJ 4.0L that is shifting almost immediately from 2nd to 3rd gear. I attempted to adjust the shift points at the TV/Kickdown cable on the throttle body but this did not make much of a difference no matter how far I adjusted the cable to each side. The transmission was also rebuilt around 7,000 miles ago and is reading full on fluid when tested in neutral with the hand brake pulled up.
Thanks in advance!
2002 Jeep Wrangler X
32RH 3-Speed Automatic
4.0L Inline 6
