I recently dunked the front of my jeep in some deep water. Headlights had water in them and I had to remove the lights to get it out. Any reason why I shouldn't drill a hole in the bottom (back side) so it can drain on its own?
Have done that on several pick up trucks with plastic lenses.
Hope to get the time to adjust them tomorrow
KC LEDs were $682 on Amazon. Toyota lights were $35 for the pair from local dealer. Took my chances on the Toyota lights based on the feedback on this thread. When I get rich I can go for LED and what have I lost? The cost of a ChickFilA lunch….
Got the old headlight wiring patched back so I could it would be working when I put the Toyota headlights in. I also ordered a set of 100/55w bulbs to go in them. My idea the 55w low beams for in traffic and around town. The 100w high beams so I can see the deer crossing the road in front of me. Gotta do my bit for wildlife preservation ya know. It’s a bit early for deer season anyway
Also ordered a new set Hella 500 fog lights to go along with the new head lights. The original factory ones have been having issues for a long time now and I figured since I’m already working up front there. Besides the LJ is paid for and got to spend the money somewheres
Well, after 500+ posts and 107+ thousand views I thought I would add my .02 cents to the thread and highlight my install. I decided to use the included harness that came in the kit to future proof if I decide to ever go with the Hella 100/80w bulbs but also take the circuit load off the MFS.
For harness routing I found a hole just below the pass side headlight opening in the core support (next to the radiator) to pass the driver side plug/harness branch through and routed it along the top of the grill and zip tied it to the harness that is already there. It is completely hidden and the routing turned out great. I am also looking for a plug/cap or something to cover up the driver side factory H/L connector that is no longer used but haven’t found anything yet.
Next, I routed the power and relay/fuse side of the harness along the top of the passenger fender (orange line).
I decided to mount the relays under the fuse box to somewhat hide them and use space that would probably never be used for anything.
I decided to buy the fuse/relay bracket kit from Cruisermatt’s (link: https://cruisermatts.com/products/koito-headlight-fuse-relay-bracket) to see if I could make one of them work. I ended up using the one circled in red but straightened out the tabs to be able to mount it vertically on the side of the fuse box bracket.
At the risk of being a little biased (LOL!!), I think the finished product turned out pretty good. The battery terminals are getting a little busy but I think it’s a controlled and organized spider web (Double LOL!!).
As said before, the actual install was pretty easy and straight forward but the harness routing and relay/fuse mounts while not difficult either, were the time consuming parts of the install.
They doI've got a new set of Hella 500s, I do like the look of the stock fog lights better. I might have to see if the innards and lenses of the 500s will fit the stock housings.
