Big 7 cables — engine block vs cylinder head?
umupfumu
Wayland, MA
I'm sure this might seem like a dumb question to those more knowledgeable, but I appreciate your patience.
I am installing a big 7 battery cables kit in my '05 TJ. There's a black cable labeled "bat neg" to "eng block" and another labeled "fire wall" to "cyl head".
The engine block ground I'm pretty sure is that nut w/ the etorx bit at the end, but where do I put the cylinder head ground? I don't think I took any other ground cables off when I was removing the old cables.
I'd run them to the same stud on the block or I'd go from battery to block and battery to firewall.
It's one of many little details that made me dislike the kit. I have hydraulic crimpers... easily could have made my own. I was hoping for a well thought out kit with instructions and it really seems like random lengths of wire and a cheap fuse holder without a bracket. Make sure you get that fuse nut tight.
  • Wow
Reactions: NashvilleTJ
On my '05, there is a woven wire strap on the driver side from the hood to a bolt on the firewall. There is a second woven wire strap from that same bolt to the driver-rear bolt holding the valve cover down.
Green - coming down from hood. Red - the ground wire to the head. Yellow - the bolt is down in there, almost impossible to see, and harder to photograph.
Reactions: Rickyd and User4574
Oh interesting. I'm not planning to remove that. Well, I guess adding another ground wire won't hurt anything?
Reactions: OldBuzzard
