Got a 97 frankinjeep been working on steering and suspension but I hit another roadblock old tie rod ends way bigger than the stock size. The axel is a Dana 44 transplant
Maybe your FrankenJeep has Curry (Currectlync) steering? If so you can get replacements at Rockjock4x4.com.
Have you identified what the axle came out of? If the 5x5.5 is its stock bolt pattern that should narrow it down significantly. Post a bunch of pics of it and someone may be able to spot or google figure it out for you. Measure it WMS width would probably help
Without that, I’d break out the calipers and go backwards from a site (like Dana) with TRE specs listed.
Talking taper on ball joint? Sorry still kinda new to this.
Will stock tj steering knuckles fit? Seems cheaper since I already have new tie rod and drag link that I can’t return
Y'all were spot on, it is off a wagoneer. Searched C38533 that was stamped on passenger steering knuckle. Need more than ends all ball joints are wore out and one is fixed
Check out the rock auto pics, they’ll include the factory bar on the fixed.
