Utah Moab in May 2025
So… talk about a scary drive home. About 20 minutes from home, doing 70 on the highway, I lost all steering going into a curve. Lost the nut for my pitman arm 😬
Missed oncoming traffic by seconds. Went off the side and thankfull didn’t roll. Glad it happened here and not the next few curves which would have been game over…
This had potential to be so ridiculously bad.
Holy shit dude, glad you and the kids are safe! Probably a good reminder for the rest of us to check and paint mark bolts and periodically check them. Usually people struggle to get that specific one off, so that's extra surprising.
Threads look fairly dirty for the nut to have just fallen off.
True. Have no idea when I lost it. I know it was there before my trip, but I didn’t notice it missing when I was under there yesterday. But I wasn’t actively looking either.
That’s nuts, glad everyone is ok.
I think your guardian angel was working overtime today…It could’ve been so much worse than it was. Happy to see everybody is still smiling
Yeah. It literally could have happened anywhere, and this was literally the best possible scenario. I was able to use the new satellite feature on my iPhone and borrow my neighbors trailer to get it home.
I mean, we wheeled are kinds of ridiculous things that loosing steering would have been catastrophic the last few days. Not to mention all the highway driving. The more I think about it, the more it freaks me out.
Reactions: Kiwi TJ
So what would y’all do? Slap a new nut and washer on? Good excuse to upgrade to PSC? I’ve not done anything aftermarket before. I’ve got little experience with steering components.
New nut and check it religiously.
But, if you want and need PSC by all means.
Reactions: Tob
Your axle might be too far off oem, but I'd go back to y-link (stock) steering geometry to start. Your steering damper looks like it was hit too (normally that's on the drag link, not the tie rod). Do the tie rod flip. But the pitman arm back on to torque and paint pen it. Get in the habit of checking that mark. Since doing the midarm I am checking every time I leave home and leave a trail.
Holy moly glad that you're okay that's scary
Starting a warranty claim with Northridge 4x4 on my RGA Discovery rear axle shaft. Seems to be bent so will get a video and send it off ASAP.
Didn't think I hammered it much except 2 short bursts at Moab.
Only backed down for a second shot at one obstacle.
Turns out the axle is not bent. One of the 4 axle mounting nuts was not torqued. Not finger loose but not 40# either. Torqued all and the wheel back wobble is gone.
We are in Moab for a short bit and it is so lonely without our jeep friends!! (We are getting by but it’s so much more FUN with our friends.)
Great to see you out, Jules! Has it cooled off a bit in Moab this time of year?
As suggested, I'd add a new nut/lock washer and torque to 185 ft/lbs.
Its funny you mention the PSC upgrade. When installing my JK axle, I went with a PSC box and a RockJock (TJ to JK) pitman arm. I checked both the sector shaft and pitman arm for burrs and both seemed to fit up well. When installed, I noticed the pitman arm seemed to engage a little lower on the sector shaft, but had full nut to thread engagement. The pitman arm was torqued and removed several times and it would not install any deeper.
When I returned home from the new build shake down run, it was apparent the lock washer had opened a bit (there was still tension on the nut and my paint marks still aligned). It looked like the pitman had moved up higher on the sector shaft. I retorqued the nut (with locktite) and was able to get an additional turn on the nut. After a second trail run, I noticed the lock washer had a tiny gap visable. I noted my paint witness marks were still aligned on both the lock and nut. This again indicated the pitman arm moved up the sector shaft. I reinstalled the lock, nut (blue locktite) and again was able to pull about another 1/4 turn to 185 ft/lbs.
After dealing with this twice, I am certain the RockJock pitman arm coating is the culprit. I am assuming the turning forces of the sector shaft splines to the pitman arm splines were enough to break the coating up and create a gap. This ultimately allowed the vertical movment of the pitman arm up the sector shaft. That said, I am fairly confident my pitman arm is fully seated now. :)
What pitman arm did you use on your axle swap?
I am sorry you went through that experience on the roadway and am glad you are ok!
Reactions: lBasket
That is one of the unfortunate side effects doing a JK axle swap, you lose the ability to run the stock TJ style steering.
