Hello, I recently bought an 06 Jeep TJ with 71K original miles, that had barely been driven the last couple of years. There were of course a couple of things that needed work, but the main issue I was experiencing was a hard shift from 1-2 when the Jeep was first started, that would go away after maybe 5 minutes of driving. If I unplugged the battery for 5ish minutes and plugged it back in, it would go away for maybe a week. Then the period it would work after unplugging started decreasing, until it was eventually down to maybe a few hours when it would start doing it again.
If you are decently adept with a soldering iron (THT soldering at a very basic level) this is a completely doable fix. I do have a degree in Electrical as well as Computer Engineering, but I probably could've done this fix with my limited soldering experience as a 13 year old realistically. I would only recommend this if you can't afford or need to put off buying a replacement PCM, as once you've "broken the seal" of your 05-06 PCM it's probably just a matter of time (I would guess a few years) before corrosion takes out the PCM. I attempted to reseal, so I plan to update in the future how it lasts.
To me, the unplugging temporarily fixing the issue was indicative of an electrolytic capacitor leak, something that any of you that have worked on old electronics might be familiar with. I bought a pack of 35V 220uF capacitors, rated up to 105C. I recommend ordering from a reputable online distributor (not sure if I can list names) but basically not from Amazon. I'm sure the Amazon caps would work, they likely just won't last nearly as many hours.
Anyways, my Jeep has been shifting perfectly since this repair so I wanted to post this in case it helps anyone else. If anyone is really interested, I could post some pictures with a little bit of a 'How to'.
