Starting another vibe after re-gearing thread, because mine seems.. different.
Info on my shitbox:
4.0 / NV3550 / Dana 30+Dana 35.
33x12.50r15 STT Pro Coopers, 1.5" spacers, factory Ravine wheels.
Revolution Gear 4.88s, TrueTrac LSD rear /open front.
Tom Woods rear shaft. Factory front.
Rough Country SYE.
160k miles.
3" JKS springs.
Rough country x-flex control arms.
"ZJ" steering components.
Center frame repaired with RustBuster components.
Rough country single adjustable front track bar, rough country double adjustable rear.
Re-geared my turd less than 400 miles ago. Getting a "rumble strip" kind of vibration over 35 ish with clutch depressed. It is also present at higher speeds (50+ we'll say) with it in gear.
Over 50, under around 1/4 throttle (in gear) "blips" a vibration until it gains RPM/more throttle input. Much more severe with clutch in.
Had a Rough Craptry shaft and replaced it with a Tom Woods shaft which did improve the vibration by around 20%, we'll say.
Lift was installed last year before the regear, as well as tires. No vibes then. Pinion angle has not been messed with yet. Changing engine mounts tomorrow, but I'm doubting that will solve anything.
Any thoughts on what else to look for?
Info on my shitbox:
Rough Country SYE.
160k miles.
3" JKS springs.
