I picked up some JK wheels & tires, so now I need adapters to correct the bolt pattern. Figuring out what size spacer is probably more confusing to me than it should be, but here goes.
I guess question 1 is what is the minimum thickness spacer to clear the existing studs?
And then question 2 is how thick do I need them to be to give me the right backspacing & all that?
The tires are 17"x7.5", and the offset is 44.45mm. I'm assuming its in mm, although why we measure some things in Freedom Units and others in metric I'll probably never understand. My existing wheels are pro-comp 15"x8" steel wheels, which look to have a -19mm offset, but I don't know that for a fact.
