Well, something like that...I'm thinking 51 is more what Jeff has said he wants.
And you get another one...
Well, something like that...![]()
Could the problem be that when you reduce the diameter of the ring gear, and then set the ring gear pattern in the middle of the teeth? I would think the R&P would not mesh correctly because pinion depth is off.
I'd go for the deeper pattern that's biased towards the heel too.
So, Ben agreed with Mike on that one.
So, it sounds like I need to decide between these two setups. Anyone have an opinion on which way I should go?
What did I win???
I just went back and looked at both patterns. The 52 is the best non-deep pattern. The 49 is the best "deep" pattern that still works. If you want to be slightly deep, then 49 is your best option.
They would never make any money if they did.I doubt that most gearing shops spend half the time y'all do on their customer's gears...
Nice, my eycrometer is not that far off lol. That's why I asked about the 49/7 backlash. Not that it matters but that's the pattern I would run.
One more silly question, are you installing the side adjuster retaining clips and backing them off in a "locked" position when checking backlash? I am always concerned that under pressure the 14 bolt side adjusting nuts are going to try and loosen up. I have never spent the time to check them when I do an initial teardown. Doh.
Interesting thought, Flux.
I don't install the retaining clips when doing the setup. But I am very careful to locate the adjusters in the position where the clips can be installed. When properly installed - at least on mine - the clips actually press onto the rounded ends of the adjustment slots, and keep the adjusters from moving at all.
That said, if I somehow positioned the clips to be centered in the slot, there could be a little movement. My guess is that this would allow the adjusters to move about 1/10 of the movement of moving an entire slot.
To validate my preload, I've mic'd how far the adjusters move when adjusting one slot. It's 4 thou. So at most, if the adjuster were to move the entire length of that freeplay, it would move less than a half a thou.
That said, on the ARB the preload spec is 15 thou - or a little over 3 slots. That is actually a lot of pressure on the adjusters, and I think it's unlikely that they would move given that much pressure against the carrier bearings. Certainly possible, but as I said above the movement allowed would not be consequential.
That does bring up an interesting thing about setting backlash on the 14 bolt. It is not infinitely adjustable as you might think, as you always have to position the adjusters where the retaining clips can be installed. Once the preload is set at the very beginning of the setup, you adjust backlash by moving both adjusters in the same direction one full slot at a time. This is how you maintain the preload once set, and always results in moving the carrier 4 thou in one direction or the other.
That is why the backlash numbers on my labels move around a good bit with each different pinion depth. Backlash spec on the 14 bolt is 3-12 thou. For my setup I want to be tight, and target as close to about 4 thou as I can. That is the reason my backlash numbers go from around 4-5 to around 6-7. If I adjust the pinion depth and get a backlash of 6-7 I can't go any tighter because one slot tighter on the adjusters would take me down to 2-3 backlash. It's not a 1 to 1 corolation, but it's close.
Anyhow, a nice thought exercise as I'm sitting here drinking my coffee. Now I'm off to button this thing up. Should be back on the road today.
I'm curious about the backlash on these. Why do you want that to be on the tight side so much?
If you're pinion depth is 3 thou deep, and the backlash is really tight, it doesn't give the gears a whole lot of room to mesh. In a racing application I might understand. Not so much for this. Is it a 14b thing specifically?
I'm just thinking about the noise and grinding feel you had.
