Same here, I couldn't find any bad reviews, but did find several good ones. In some case you can reuse stock bolts, but replacement is recommended for some bolts (TTY bolts etc.). BDS manual says to consult the OE manual. The parts list in the 2" kit is in their following installation manual, so I assume these are the parts that come with the kit and that additional OE replacement bolts may be required beyond that.
http://bds-suspension.com/instructions/034204-11-06-08-114202.pdf
I'm not too concerned about the details since I'm not doing it myself, but it is good to know how the mix and match may or may not cost more. It is also good to know what bolts should be replaced so you can do it properly, or quiz the shop about it![]()
I’m going to call BDS and see if I can get the springs and hardware and how much they charge. The $420 with the mix is with tax. You have a good point about the hardware. I will be DDing this setup and was a nice ride. That is why I’m getting anal about it. What brand tires do you plan on running?
