Was finishing up the hardtop harness, pulled the driver's seat to work on the tilt mechanism and had to change the multifunction switch so it did sit for about a week (not unusual, never a problem before). I inadvertently ran the battery down pretty good and charged it overnight 2 nights ago. I buttoned up most of the dash but I left the rear wiper, defroster and foglights disconnected because Im finishing up a charging outlet in the lighter slot and need to get a grommet.
This morning I started it, gave it a little gas, and it actually rocked a little side to side. It wasn't violent but unusual enough that I turned it off, got out just to make sure nothing was under a wheel. When I tried to start it again, it immediately died. Tried it a few more times since, same thing.
Battery is fully charged.
It's not throwing any codes (key method).
I plugged the C1 C2 and foglight connectors back in in case that was some quirky thing (although it started and ran before I plugged those back in).
When doing the MFS I had a REALLY hard time getting the top part of the steering shroud out, but also putting it back on. I had to muscle it to where I felt like I would break something. I did watch videos. None showed a smooth way to get it off; they showed guys wrestling with it and one guy just said, "let's take this off" like it was nothing but didn't show how he did it. I did take out all 3 screws and moved the steering column up/down. There's not a lot of wiring in that area but wondering if I could have pinched something.
The key it started up with this morning is the original key, the one I always use. I did try the other two I have that aren't original. I checked the build sheet, and it doesn't say anything about a skim key. Figure it's still worth mentioning that while I was doing the MFS and hardtop wiring, I *was* using one of those non-original keys. (Just wondering if there could be some kind of quirk of it, resetting itself to a different key, but then figure it would start up with that other key this morning.)
I know others have mentioned the CPS; I don't know how to trouble shoot that yet so I just figured I'd start here.
