Questions about GM V8 conversion on 98 TJ
G H D
virginia
Hello all..
im in the process of a chev v8 conversion into my 1998 tj, my goal is
more horsepower and a "sleeper " looker,,,i mean externally very little
evidence of conversion... im wondering if any of you have made the change,? im
going to be using the Holley sniper efi, and am wondering if anyone has had experience
with the signal output for the tachometer, ive been unable to get any satisfactory
information from holley... wondering if someone makes a level converter, my desire
is to keep the dash instrumentation stock appearing..
any help or direction would be really appreciated,
glen
Hello all..
glen
What engine are you planning?
Reactions: speeding_infraction
Lots of folks have done LS conversion. Not many have done SBC.
If you're already planning on fuel injection buy a $500 5.3 LS with a computer...or a Suburban/Yukon/Truck with everything you need in terms of LS, wiring and PCM...sell/scrap what you don't need.
an early probably 80's corvette 5,7 litre (350) have totally rebuilt with my own mods
its ready to drop in, just getting to the fine points stage and want to keep instrumentation
original as possible..
Reactions: ColoJeep
The biggest reason that the LS is more common is that alot of the early adopters were in CA where there are some more stringent rules about engine being from same or newer model year and all the emissions equipment from the donor being retained. Well that and ODBII support makes the stock hardware easier to setup.
Functionally the SBC vs LS doesn't really matter in this context. SBC from 87 and later have roller cams and its much less of an issue to install them in earlier ones than in a TJ 4.0. There's advantages in the factory LS heads, but there are aftermarket SBC heads that can get you to the same results.
As for Holley EFI, a good friend of mine in ABQ is running a a blueprint SBC engine with Sniper II in the Ford coup hotrod his dad built. He's an amazing welder, but not much into auto mechanic work and is working with a shop down there. He's been having issues with the EFI cutting out somewhat randomly and has been working with the shop on the tune. The Sniper EFI system is a CANBUS system, not ODB II, whereas the TJ's JTEC computer was ODB II, but came out prior to the emergence of CANBUS being common in parallel. That may be contributing to the issues getting the two to talk. The TJ gets it's RPM signal off the Crank Position Sensor and the pattern isn't just a single pulse for each rotation.
This video has some Pico traces of the crank and cam sensors in a TJ, which probably helps explain why the emulator is probably going to be helpful.
View: https://youtu.be/OF6i5ALkEHI?si=oLFt7xVXCO6OGyan
Or put another way, the signal on a 4.0L flywheel is setup on 120 degree intervals aligning to the 6 cylinder layout while the V-8 signal will be setup on 90 degree intervals.
4.0L Flywheel
my friend that is actually doing the hardware work if installation has had multiple experiences with the holley system and seems to be fairly knowledgable with its quirks so im pretty comfortable with this... thanks for the input. im excited glen
The whole emissions thing takes away a lot of options in areas that have testing , you don't want to be caught , ask any of the rolling coal diesel shop boys.
Reactions: G H D
I was just saying that the other day, I moved to a free state that doesn't do any of that crap lol. Now, it should be mentioned that rolling coal is generally frowned upon in the diesel community, especially on public roads. Go try and ask for a "smoke tune" on any of the diesel forums, you'll probably get banned but your post would definitely be deleted.
Reactions: ColoJeep
all good info and thanks,,, however im not using a ecm,,, old school with the exception of the Holley efi.
the jeep tj computer will all remain intact,,,all i have to do is make the sensors temp, pressure, rpm ,readable on the
jeep obdI sys.. got it all covered except the tach,,looks like the novak emulator will do the business... otherwise ill build something, digital design is my thing.... glen
If you're able to make the Sniper output the same tach signal as an LS, this guy got his tach working on his pre-'05 TJ without an emulator. Here's a post I saved from the LS Swap Wranglers FB group.
Holy moly, That's my old FB post before I locked my account! I changed my name due to a crazy ex. Glad to see it's still helping.
I understand that, but you'll need to get the tach signal from somewhere even to feed the emulator. That's why I was saying if you can make the Sniper output the same tach signal as the GM ECM in the post I referenced, you might be able to get by without an emulator. Even with the emulator, its going to be looking for the standard GM tach signal.
That is awesome! Yes, I had originally planned putting my LS in my '99 TJ and was going to absolutely try that, hence why I saved the post. I ended putting it in my '06 LJ, so ended up not using it and went the emulator route.
Well perfect, you're just the guy I'm looking for lol. Do you know if this might work for a 1996 xj? I know the whole instrument panel and how it worked changed in 97, but I might as well ask
I honestly couldn't say. It depends on what type of tach signal the XJ is outputting, and I don't know if it changed between 96 and 97.
Reactions: G H D
