For now, no. I certainly thought about going whole hog, but decided to go a bit different route. Just keeping it simple for now. Standard bore as my engine has only 80k on it and I know it's entire good service history, as it's been my jeep from day one. 0.027" Cometic head gasket to help increase compression to 9.78:1 without decking the block. The rest of the parts are a couple weeks out.
What I'm hoping comes out of this is significant increase in torque and power in the 2000-4000 rpm range. May or may not be a wash, but the stock size valve should help with intake velocity at lower RPMs and the head already flows far better from the mid to high rpm range thanks to the much improved exhaust ports over 0331 TUPY.
The cam(s) I want to use aren't available right now, so I'm going to keep going with my known good stock cam and lifters for a bit. There'll be meat left on the bone for sure. It'll also help me choose between a couple of similar cam options.
Is this a crack? That’s a beautiful head, I hope it’s not!
