Wow, this past weekend has been a process for sure. We found out that we either have a cracked cylinder head or just a bad head gasket. So after attempting to remove the cylinder head on my sons 2001 TJ with the 4.0 we accidentally cracked two cylinder head bolts, stripped one and stopped with the last one we could not loosen. After a few hours of internet searching, it appears that the broken bolts have to be tapped, drilled and removed with a reverse bit. The issues we are having is that one stripped head is against the firewall and the other snapped bolt is across from it along the firewall providing us with no good overhead access to reach them. We did pre-soak them with PB blaster but it seems that the lubricant did not get all of the way down because of the high torque specifications on the bolts.
Can anyone provide some specific guidance on how to remove the bolt with the stripped head and the other two that have snapped? Both snapped bolts are broken about 2/3 - 3/4 of the way down in the cylinder and I do not have any of the extraction tools (yet). I believe I may have to get some, but advice on what ones to use to get that far down as well as how to get good access to them being against the firewall with no real headroom is greatly appreciated. Do I have to find a right angle drill attachment, pull the engine to get to the two areas or are there other ways? We really cannot afford the tow to a shop and the high hourly rates to help with this. He has to get back to school so we only have two more weekends to get this accomplished. Thanks all in advance!
