Correct me if I'm wrong, but didn't you upgrade only the rear to Fox 2.0 w/DSCs, which means your front corners haven't been upgraded yet to match the tuned rears?
If that's the case, then I'd complete the suspension build. Otherwise, I'd consider dialing in the tune or going for a ride in a rig built by Blaine before poo pooing the comparison as being ridiculous. The handling at speed, especially when pushing it in boost, is the biggest thrill of the experience.
To a much lesser extent, I noticed an improvement in handling after pairing 35s with 17" wheels instead of 15" wheels. It all adds up.
Ha, ha. Yep, I’m only 1/2 dun
. Ridiculous is perhaps the wrong word. I did not mean to offend. I ran out of time last winter to do the front stretch/mid-arm/coilover like I did in the rear. My TJ build has been a slow evolution for 7 years and it gets regular road driving between modifications. So it has been interesting picking out the subtle and not so subtle differences each time I make a change to suspension, steering, weight balance or wheelbase. Separating the front and rear has also been revealing because I can really feel how uniquely the 2 ends of the rig behave (the rear is better).
We (you and I and others in this discussion) may not have the same definitions of sporty. For me, a proper sports car has quick and composed reactions to both driver and road inputs and, crucially, communicates to the driver what’s happening at the contact patch. Much of that comes from low mass located close to the ground. Engine power, though welcome and fun, actually has little to do with how sporty a vehicle is in my estimation. Some examples of cars I have driven that I consider sporty:
911GT3, C8 Z06; I expect little argument on those.
Mazda Miata; If hp is an important metric, you may disagree.
1985 VW golf; I throw this one in because I owned one for quite a while (base model with manual transmission, manual brakes, manual steering and a whopping 85hp). That car was a riot at 10/10ths which was easily approachable on the street because of it’s very modest limits. It would rotate if you lift the throttle in a turn so you could drift on command using momentum rather than hp. Most importantly to me, putting your hands on the steering wheel was akin to running them along the surface of the pavement, allowing you to walk the car upto and beyond the adhesion limit and easily back again.
My jeep, while very fun in its own way and still improving, will always suffer in a road driving comparison to any of those (not a criticism, its just not a sports car). But maybe I’m not doing it right
