I dont care
Throughout most of this ordeal, something else seemed odd beyond the more obvious describeable problems that I could never make sense of when the engine was running.
When the Walbro pump arrived, I rebuilt my original Mopar fuel module that I had replaced about 90k miles ago with a Bosch module.
Back when I decided that the pump has died, I checked voltage at the connector and would get a brief pulse of 12v with the ignition on. Before I dropped the tank, I plugged in the rebuilt fuel module and got nothing with the ignition on.
I check the connector again between power and ground and now suddenly have no voltage. I check power to the body and have 12v. That suggests a bad ground in the wiring harness.
I start checking continuity throughout the ground wire all the way to the engine block. Each time I have continuity. I test voltage at the plug again and find 0v again.
Desperate to find something, I hook up each fuel pump modules to a M12 battery and both turn on.
I do all of this over and over and over again trying to figure out what I am missing because nothing makes sense.
I keep digging and soon have the entire engine harness pulled out and opened up looking for a damaged wire. Nothing. I keep checking things over and over again.
Eventually, during yet another continuity check, I notice a very brief loss of continuity when I moved the growing tangle of a wiring harness. I start poking at stuff and soon discover a splice I made to the ground wire several years ago would lose continuity if I moved it just right.
That was the problem.
Okay! For a guy that gives people grief about precision, that's out of character.
My guess is his response meant he didn’t have a spelling mistake near the top of his priority list when describing a much more interesting issue with us. Not that he’s happy to make communication mistakes.
And I won't comment about your intentional contraction problem either.
Has it already been 9 months? Time flies.
Without have the schematic in front of me, could it be a switched ground problem? As in the fuel pump relay isn’t latching to ground with the ignition on (rather than ground being constant)?
