My new 5 Gallon fuel tank showed up today, and I was able to score it in the elusive OD Green! Its actually very well built, and it fits better than I thought it would in the roof basket. :) Now I can get a bit further down the trail carrying an extra quarter tank of gas.
View attachment 49562 View attachment 49563 View attachment 49564
https://www.amazon.com/dp/B074QNQMDV/?tag=wranglerorg-20
I like that look and that its out of the way...but...how do you get it down from there?...Do you have to remove it to fill your main tank, or maybe siphon it using a rubber pipe the old gasoline mouthwash system ? lol
Reactions: EJD
That is pretty cool, @EJD. I like it!
*Edit: I just read their description of the product. Check out this claim. I wonder what exactly they're thinking of...? o_O
"Multi-Function Desing- When driving in the field, it can be used as an anti-skid plate, strong anti-rolling capability without deformation problems."
Reactions: EJD
Installed some stock rubicon rocker guards on my LJ. Drilling through the tub was a bit nerve wreaking at first.. but turned out easy.
Lol, oh yeah you would remove it from the rack, unscrew the cap and there is a spout inside that you flip around and reconnect. Then you grab the whole thing and pour it in just like any other gas can. Not a big fan of the mouthwash system. :)
Haha, this thing is actually really heavy duty but I don't think I would use it as a skid plate! It comes from Hong Kong so i'm sure their wording is slightly off, especially after reading some of the warnings on it. It does have all 5 star reviews too, so we'll have to test it out and report back.
@EJD, are you at all concerned about the extra 31 pounds stressing your hardtop at the carrier's mounting points?
Not at all, and its more like 45-50lbs filled, since its 5 gallons and a gallon weight a touch over 8 lbs, plus the 5lbs of the container itself. In the back of my basket where it will most likely live, it sits directly over the rear crossbar. That alone is supporting the weight and not flexing the "landing pads". If I had it in the front for example, where it is not directly over a crossbar, it may actually flex the mounts a touch, but I am very impressed with my whole rack system so far and i've carried a ton up there with no problems. I've even stood in my basket and I weigh 180lbs. I would not hesitate to load it out with 150 of gear and baja, some might even go more!
Reactions: Kiwi TJ and Squatch
Is there a reason people leave their shackles on the bumpers then use isolators so they don't hear them rattle? Mine are in a duffle bag with all my recovery gear. Just curious. Thanks.
Looks cool when the shackle is on there lol!
Actually, gas weighs in at 6.2 lbs per gallon, whereas water weighs in at around 8 lbs. I remember being surprised by that information when I read it. So you're actually better off than you thought you were! ;)
Check this out:
http://www.garbermetrology.com/gas-water-which-is-heavier/
Dang, that's pretty impressive! And having it over the crossbar seems like the logical choice (I said, whilst channeling my inner Mr. Spock). Nice set-up, for sure!
Reactions: EJD
Check this out:
Really?!
I had no idea, but yeah that is better yet...good deal! Honestly I was thinking to myself that loading a 50lb item up above my head onto the roof might be tricky, but man 30lbs and some change is much more manageable.
Can't wait to show you guys a few pics of it loaded out on an upcoming overlanding trip here i'm planning.
Reactions: Squatch
Just stared at her thinking of all these things I want to do but can't afford at all to do especially 33s because I'd have to re gear for that. View attachment 49585
Don’t worry about the re-gear. You can get to 33’s and worry about that later...really
Reactions: ac_
Thinking about crawling up that green wall behind you?
Those fender flares are just begging for some larger tires to help fill the void! As much as I like the stock flares, those come in a close second. Very nice!
Reactions: Kiwi TJ
