ohiopatriot
A Detroit Locker requires.......(get this) a Detroit Locker. Less expensive, very reliable, no drilling, no air compressor, no switches, no relays, no cables, no plumbing/wiring, no worries.
Yes thanks, I did know I had to change both front and rear. 5.13's put me in a higher RPM on freeways how much more anyone know? I am afraid to get to high of a gear also, no?
What did you enter for a tire size? It should be a bit less than what the side wall says.3.73 on the left and 5.13 on the right courtesy of http://www.grimmjeeper.com/gears.html
They do cost more I am looking at compressors, they look to be 200-400. Price wise the next best thing is an Eaton E-locker. For me they seem to be an easier method to install and maintain? I may still go ARB but price has me going towards Eaton E-lockers.
With the ARB do you need something like a small tank with check valve that can stay presurized while the lockers are being activated? With ARB do you have to wait on the system to pressurize before it locks?
The compressor doubles as air for anything else you can use air for, though I'd use that only in a pinch given its primary function.
The CKSA12 is only $170 from Amazon.
You can turn on the compressor at the beginning of a trail and leave it on the entire time, engaging the lockers when needed. Otherwise it takes about three seconds (maybe).
This is not completely correct. Not all compressors can be used as a secondary source of air.
You said exactly what I quoted, which isn’t a correct statement and can be very misleading for someone like the OP that is asking basic questions.
Topics that should be off limits
Lockers
Tires Brand/size
Type/brand of oil. (All oils)
Wenches-including wire vs synthetic
Salvage titles
Safe topics
How stupid JKU's onwers are (current members excluded)
Dogs - must include pictures
How cool are jeeps are
Yes I have thought of this also. This is a good pointNo, and no. A button on your dash instantaneously activates a small compressor mounted under the hood & you're locked, shut if off & you're unlocked just as fast. The compressor doubles as air for anything else you can use air for, though I'd use that only in a pinch given its primary function. I have a tire repair kit & the air hose attachment in my tool box. For anyone that wheels but cites the extra cost associated with the ARB needing a compressor as a negative I have to wonder, are you seriously wheeling without access to air? I'm sure many e-locker guys also have onboard air somewhere so to me that's a wash.
I have no opinion one way or another about e-lockers, never used them, but I'd think twice about making a close judgment call based on nothing more than this perceived need for an expensive superfluous part...
Thank you very much for this info LJ looks like I may be doing 5.13's(assuming automatic trans) 3.73 on the left and 5.13 on the right courtesy of http://www.grimmjeeper.com/gears.html. overdrive at 80 mph with 5.13s puts you at ~2949 rpms. I've driven at 3000-3500 rpms on the freeway for hours at a time for the last ten years without any mechanical concerns.
They are supposedly extremely realistic.Synthetic wenches should be moved to safe topics.
Rubber or vinyl?Synthetic wenches should be moved to safe topics.
Or to "Your favorite movie of all time" (Think "Lars and the Real Girl")Synthetic wenches should be moved to safe topics.
Unknown. But likely a 30 spline and easy to determine. Just pull an axle shaft and count.So if a shop put in my dana 44 as a used rear end would I have a 30 spline or a 35 spline or would it be unknown with out taking it apart?
