The fat harness does not need to run into the cabin. Only one single write runs into the cabin to the switch.
Man this is turning out to be the "Chevy Ford" debate.
Honestly like i said before, I haven't ran the wires yet, but regardless of it going through the firewall or not still I think the air lines are much easier to route.
So far my opinion is based on my experience. I had front and rear ARB's in my YJ and I had a ARB compressor. I did all of the work myself and it was phenomenal. I decided on this build to try the elocker. I am only pointing out what I see. Also as a little background I worked at a Toyota dealership as a drivability/electric technician, so I am not afraid of the wiring. I am just stating so far based on what I see at the point of where I am in my build that the ARB looks much easier. Either way I guess, if you feel more comfortable with the wiring do that. I don't think either is bad or good or better, I merely am just stating differences as I seem them.
Use whatever makes you more comfortable. I don't think you can go wrong either way.
I surely didn't mean to start a debate.
Not to fuel the fire anymore. I have no experience with an ox locker. I don't know if they are good or bad in reality. but the reason why I didn't consider it was I didn't want to mess with routing the actuator cable. Although I have never done it, and maybe it is simpler than I expect it to be, I don't want to mess with it personally. That doesn't mean it is a bad system, it just means it is not for me. I hope that makes sense. If anybody puts an ox locker in and figures out a fool proof way of installing the actuators, more power too you. I will wheel with you no matter what locker or no locker you pick. I will even wheel with you, if you have a Ford or a Chevy! That is just who I am1
