TJ doors off mirrors
I cut a deep slit in mine with a dremel and then used one of those flat head screwdriver bits with a socket and wrench. I hit the socket wrench handle with a hammer (like an impact gun) till it popped loose.
Its a good idea to scrape the paint out of the torx hole and then tap the torx socket in there with a hammer before twisting so you get full lock on it.
This! You might actually already know this but for anyone that does not here is a link. These work really well.
https://www.craftsman.com/products/craftsman-impact-driver
Hi Nuggsfan, I have the same mirrors, but they didn't fit on the windshield mount. I had to actually install them down on the lower mount. I thought if I enlarged the holes, I could bolt them up higher. Everything looks the same with mine except the actual mirrors. Your mirrors look like older CJ mirrors. I like yours better. Did you change the mount to mount it on the top of the windshield mount, and did you used different mirrors, or do you just have actual different mirrors than me. (I have rectangle ones) I mean do you have a link to what mirrors you actually have?
Here is the link....
https://www.4wheelparts.com/Exterio...aspx?t_c=3&t_s=465&t_pt=3282&t_pn=RUG11001.08
They are actually for a CJ 7, but the holes lined up fine for my application and it made them sit a bit higher. I am 6'5" and they seem to work great at this height. The only issue I have with them at all is the driver side mirror has a strange whistle at speeds above 30 mph. I just turn the radio up enough to not hear it! [emoji23]
Oh man, I can't remember who it was, but I believe it was @billiebob that had a good solution for doorless mirrors.
Thanks for the link
Now here for a possible solution. When I bought my mirrors, I was reading the reviews for them and someone suggested putting clear silicone on the back side of the mirror between the rubber and the mirror. I am not sure if your grommet goes around to the back, but if you can squeeze some clear silicone in there it maybe possible to get rid of the whistle. I did it to mine and it seems to have worked for me, but I have the rugged ridge actual tj aftermarket mirrors, but I like yours a ton better. I will probably change mine out again.
They were cheap enough I considered them disposable. I see the gap you're talking about though, and will try that tonight
I know this is an old thread, but can you see the passenger mirror with the doors on? That was my problem with relocation brackets, they worked great with the doors off but with them on I couldn't see the passenger mirror.
Sent from my SM-G950U using Tapatalk
The way I have mine mounted, I can see half of the mirror with the doors on. If I had hard doors, I’m sure I could see more. I only use soft doors, so the black area around the window is much wider. The half I see is from the top right corner to the lower left corner and down
Thanks. I have full doors so it shouldn't be too bad.
