Matt Robillard
@steed8950
I'm still in the same boat as you with my 05 4.0 manual. I've replaced everything, including the pcm. Also ran a wire straight from pcm to Cam position sensor with absolutely no change. My advice is to have them pull the OPDA and inspect both the gear on the OPDA and the gear on the camshaft. Mine are both chewed up. There is a tsb from Chrysler that fixes the exact problem that we are having. It was specifically for wranglers with manufacture dates in 2005. But it is well documented in another thread that they will cover it if you put up a fight. Here is where I found all the info about the E05 TSB and how it also affects 06 wranglers.
https://www.jeepforum.com/forum/f9/...-963235/index119.html#/topics/963235?page=119
