have a terra low 4.1 and want to install it in my jeep tj 1998 4 cylinder what is the best solution
currently have stock transfer,, is there a solution to this
I don't think you can do that. I'm a slight bit fuzzy on the details but I believe the 4 cylinder manual has a smaller spline count for the input shaft on the t-case. What I don't know exactly is if the Tera unit can have the smaller input swapped into it. I don't believe so since I think it is part of the planetary or part of the assembly that makes that planetary work.
