A few months back I replaced both front and rear track bars, tie rods, tie rod ends, steering gear, rear stabilizer bushings, links, rear lower control rod bushings, and all 4 shocks. Everything was original with lots of city miles on it. So I noticed a big improvement in handling and how it handles the bumps. But one thing that remained was this annoying rear end wiggle when cornering and hitting bumps at the same time. Highway driving was a constant nuisance to keep it tracking in the lane, especially when hitting head wind.
Turns out, it was mostly the rear upper control arms. I just pressed in new Moog "Problem Solver" bushings and reinstalled the control arms. Now it's so much nicer on the highway. Funny thing though, the bushing rubber wasn't all that bad. Sure, there was some surface cracks from old age but nothing serious. The biggest cause was the way the original Chrysler bushings were manufactured. The hole in the center of the Moog bushings was a perfect fit for the 10mm bolts. With the originals, the holes through the center were about 13mm in diameter and they had these protrusions to center the bolt. Most of them were pounded off allowing too much movement. The bolts were pristine with no sign of any wear.
