Thank you. It ain’t new though, as it has a little over 180k on it. The third brake light above the spare is a cut down version of the original. The one below the spare is one of those types that fit in the receiver hitch. Yes, I have four brake lights. Having been hit from behind multiple times before (I used to have a red pickup), I want no excuse of “I didn’t see that you were braking.” Being the OCD guy that I am, I like to polish my vehicles a lot.
I took the Rampage too off today and tried to gently iron the seam seal tape back in place. It must have been made late in the day on a Friday. The tape was placed too crooked to work. So I went and bought some clear gorilla glue and glued the seam down, then covered the entire seam with a waterproof adhesive used for tents, awnings, and canopies. Once that drys, I’ll put it back on and check it again. For the missing foam pieces I have a .98 pool noodle I cut up. As for the missing rods, I’ll probably use some painted black 1/2” pvc pipe, or something. I like the way the top looks, but it’s almost worthless if it leaks.
