I have the same ones. They have held up great and look even better.This is what I installed. The backup lamps could be brighter. Other than that, no complaints.
LED Tail Lights - 4" Round Hi Visibility Stop Turn Tail Lights w/ Reverse Lights for Trucks Trailers RVs (Grommet Mount) https://www.amazon.com/dp/B072SNG9M3/?tag=wranglerorg-20
These are B.A.D.A.S.S the best combo light I’ve ever seen
https://www.raneystruckparts.com/4-round-dual-revolution-red-white-stt-reverse-combo-light/
What is required to fix the fast blinker because i know that will be an issue after switching to LED
For what it's worth, I have JWSpeaker heated tail lights on their way to replace my older Trucklites.
If I was going to do a flush mount round LED tail light combo, these are more of what I'd use. For my own personal tastes, I do not like the look of the individual LEDs being seen. These have a constant "halo" look for the running lights, while the brake and turn signal (in the center section) are the more typical LED look. They have a video that shows these illuminated in the dark to give you a better idea. No back-up lights in these particular ones, however...
https://www.etrailer.com/Trailer-Lights/Optronics/STL101RCFB.html
*I'd get the all red lens, myself. Not a fan of the clear lenses, and I feel the red lensed lights illuminate a deeper/richer red, whereas the clear lensed units are a little more washed out, or even pinkish in color. At least, that's how my eyes see them.
Do they have backup lights?
Yes. But probably not in the way you're looking for.
https://www.jwspeaker.com/products/categories/turn-signal-lights/
Those are some new ones I came across that have back up lights for a different project I have. These are what I use, no b-up light tho cause I run a separate b-up light.Those look better than the ones I have. I’ll have to check yours out when we’re on the Rubicon Run.
I had you for a tailpipe guyThose look slick.
Not going to lie, I thought about if I could stick my dick in those tail lights
Very briefly, just one little hummm,
I am but I always burn my lips on themI had you for a tailpipe guy
