Colorado Krew Hangout
Here's a few
Reactions: rasband
@jjvw now you can use this as an example of how the antirock can be set for control rather than simply placing it on its loosest setting
Reactions: jjvw
@jjvw - are you thinking about doing the genright body mount shift during this off season or later? I’d like to collaborate on it whenever you do.
Absolutely. Hopefully this winter. There is a domino effect of other changes that go along with it.
I’ll be curious to see what you have up your sleeve. I’m hoping to bump those up since my lift is on the smaller side and address the related savvy outer C.
Reactions: jjvw
The easy way is to open up the hole in the cross member bracket to make room for the raised body mount.
My plan is to recess the nutserts into the skid, loose the spacers and frame wrap bracket, weld the crossmember mounts to the inside of the frame; and then attach the raised body mounts.
I’m on board with all those, seems like a solid plan. There’s some logistics of the C mount I’m unsure of, though maybe it’s just a rework of the fuel lines (and other accessories on that same frame side) will do.
Reactions: jjvw
Oh, and I want to address the protruding skid-to-frame bolts. I dinged them up a decent amount last weekend, enough to know they won’t stay hex bolts for long.
Reactions: jjvw
I know how to do that. ;)
Reactions: rasband
80 yesterday, got a tan at the pull n pay, to this:
My route to work is 25 min usually. Today was probably closer to 75 min. Lost count at how many accidents and slide offs there were. Why you would own a 2wd vehicle in CO is beyond me.
I have an install in Cherry Hills later this morning. I'm still debating if I will put windows in or just suffer until tomorrow.
Suffer. Its supposed to be back up in the 70s. I just threw the wind jammer on last night to stay a little warmer.
Reactions: rasband
Incidentally. Colorado Public Radio just got knocked off the air. It's getting to be a scary day!
I plan on leaving the office after a while, the ride home is going to be just as bad:rolleyes:
It looks like you guys got a bit more than we have down south of Denver - we are just passing 3/8" or so
