Tire pressure in's and out's
Kasterusa
Salt Lake City
Resent suspension upgrade complete, but TJ ride has room for improvement. Replaced suspension with Rancho RS5000X stocks and OME Medium/Heavy springs. No hard top. No upgraded bumpers....yet. 4.0L. How do you manage your air pressure?
1) I see many posts mentioning 22-26 psi....is that for off road and on road use?
2) What do you use for deflating? Is it important to have a quality tool to get close to exact tire pressure in each tire
3) What do you use to inflate? I have seen onboard tanks, plug and play compressors and air tanks.
Thanks,
Keith
BBCDA9BE-F70B-4E7D-ADF2-F1FD5CC902BC.webpE46B40BC-21C9-494C-8F99-23B3BA277142.webp1F3A398C-1839-4B02-877B-65B53C9BE34B.webp
Your ride will be a little stiffer with that set up but it’s a good set up , with out the extra weight from a hardtop it’s alittle on the light side.
I’ve always been told the tire pressure on the door panel of your vehicle is what the vehicle is required per manufacturer.. size of tire doesn’t affect the amount of air.
I’ve have a cheap digital tire gauge I got at a hardware store several years ago and it’s always been pretty accurate, A 5 dollar tire gauge from auto store does fine.
I use a air compressor at home or have a mobile husky one with a converter for cigarette lighter I use if out in wilderness.
32’s I run 28 psi cold.
If on a trail I air down depending on the road. 18 psi for FS roads 12 if I’m on rocks
I have a portable viair
With 35s I am 25psi in town, Hwy use 28-30 psi offroad 12 for rocks . Use Co2 tanks
Thanks,
Keith
View attachment 121168View attachment 121169View attachment 121170
26-28 psi is more for 33" size tires and that high of a pressure only for street use. Offroading, the tire pressure is much lower, usually 13 psi or under. Generally speaking, the bigger the tire the less air pressure required and visa-versa. If you're not under 15 psi for offroading you're not airing down enough.
For deflating, I have been using this one for many years and like it because it's FAST!!! https://www.amazon.com/dp/B00PADT5PS/?tag=wranglerorg-20 But you have to manage tire pressure one tire at a time.
I'm now transitioning to this one as soon as I get the time to get it better calibrated. I recently used it the first time but it lowered my tire pressure lower than what I thought I had set it for though I was kind of rushed during my first calibration attempt. https://www.amazon.com/gp/product/B00JJND26I/?tag=wranglerorg-20 Its benefit is convenience, you screw them onto all four tires at once and it does its job while you go do something else.
Compressor-wise, this is a critical device... choose the wrong one and you'll be there 45 minutes to an hour refilling your tires after you're done offroading. The little compressors that plug into your cigarette lighters are the worst at being too slow to refill our big Jeep-size tires. What to look for in a compressor for our big Jeep tires? Air volume, as in CFM... cubic feet per minute, not PSI which is only how much pressure it can pump to. A tiny road bike hand-pumped compressor can fill a road bike tire to 120 psi which I used to do, and they don't take long to do it but road bike tires are small/tiny so they don't take a lot of air to refill them.. But even though it can refill a small bike tire to 120 psi, it'd take hours to refill a big tire to 25 psi.
What you want is a compressor that can put out at least 2 CFM or more so you don't waste your time refilling tires. I installed a belt-driven compressor into my previous Jeep and it put out something like 7 CFI and it could refill all four of my 35" tires from 8 psi to 25 psi in less than a minute per tire. That Jeep was stolen so I now use a 10 lb. CO2 tank to refill my tires and it puts out almost as many CFM, it takes maybe 5 minutes to refill all four of my tires. My CO2 tank probably puts out 6 CFM.
I just can't emphasize enough to avoid the little compressors selling for $19.99, $29.99, etc.. Even though their packaging screams 120 psi, 200 psi, etc., that is just PSI and they don't put out enough VOLUME (CFI) to refill our Jeep tires in any time that is not an excruciatingly long time.
ARB makes great compressors and so does Viair, just buy the compressor with the highest CFM rating you can afford. And if it plugs into the cigarette lighter it won't put out much air because a cigarette lighter can't put out enough amperes for a decent-size compressor. Either go with one with battery clamps, or put together your on CO2 tank which you can do for under $200. If you're interested I can tell you the basics of what's needed to put together a CO2 tank system at 1/3 the cost of what they sell for already to use.
Hahahaha this is the truth. I have a nice little Viair that keep in the back, but on one of our last trips as I was packing it I realized that I had neglected to replace the blown air hose at the last minute. So instead I just grabbed the little $20 Walmart Slime compressor from my wife's truck and we went on out. At the end of the trip I must have spent 25 mins trying to get all 4 33s back up into the 20's so I could drive home. I'm surprised that poor little Slime compressor didn't burst into flames.
X2 to Jerry's advice. Make sure you are running the proper pressure for 31s. I have an ARB Deflator (identical to the one Jerry linked). I can usually air down from 25 to 8 in maybe 5 min. Offroad I usually air down to 8 psi, that gives a nice soft ride with plenty of traction. I have been using a C02 tank that I fill up 2-3 times a summer. Its usually $20 to have it refilled and it mounts to the rear wall using rubber straps. I can fill up my 35s pretty quickly after a trail run. Dont think I have ever timed it, but it would probably be 5-7 min. The negative though is that when it is out of C02, its done. Ive had to call upon others to help air back up and its a little embarrassing. Just recently I converted an AC compressor out of a cherokee into a belt driven OBA. Still in the works but once complete it should put out 9cfm and fill up tires quickly without running out like my C02 tank.
I run around 26 psi on the street with 33's. I have this air compressor hard mounted under the hood, and it fills tires surprisingly quick. It's been working for quite a few years. Some will surely say it sucks even without any direct experience with it, but mine doesn't. I did do a few minor mods to it, like replace the gauge and the fittings.
https://www.pepboys.com/onlineflow-...able-hi-volume-air-compressor/product/9357343
I’m on 37’s and run around 22 psi cold, street, and 6 psi off road. Before the beadlocks and on 35’s I’d run about 25psi cold street and 10 psi off road.
I use the same Currie deflater and gauge as Jerry and love it. To inflate I have the ARB twin compressor that also works my locker. It’s pretty fast and I’m happy with it
