RPM falling below idle at stops
Wyeth Bernardin
Bainbridge Island, WA, United States
Hi, I have a 97 Wrangler 2.5 and recently when I stop or slow down suddenly the rpm will fall below idle. It drops to about 500 rpm. I have read that it could have something to do with the exhaust but I don't want to go tearing apart the engine to find nothing. Looking for a quick fix because this car is my daily driver! Also note the temperature outside has been around 30-40 degrees, not sure if that could be affecting it as well. As it stands I'm not super worried about it because it doesn't seem to affect the overall performance of the vehicle. Any thoughts? Thanks.
Mine idles at about 500 and 600. Your water temp 30 to 40? You sure about that? 4.0l or 2.5l? Is it idling rough hesitating?
i think someone had a problem similar to this not too long ago and he cleaned his TPS and that sorted it.
there's a link on here somewhere how to do it.
otherwise like Raymond said it could be vacuum leak, check your headers, from underneath, check all the joins and welds if you find big cracks, holes or worse.. this could be your problem.
Hi, I have a 97 Wrangler and recently when I stop or slow down suddenly the rpm will fall below idle. It drops to about 500 rpm. I have read that it could have something to do with the exhaust but I don't want to go tearing apart the engine to find nothing. Looking for a quick fix because this car is my daily driver! Also note it has the temperature has been around 30-40 degrees, not sure if that could be affecting it as well. As it stands I'm not super worried about it because it doesn't seem to affect the overall performance of the vehicle. Any thoughts? Thanks.
Not sure about the 30-40 degrees..?? Try cleaning your idle air control (IAC). It's easy, quick and cheap to do.
Reactions: Jerry Bransford
Check this thread out. Jerry has a great write up on cleaning the IAC.
https://wranglertjforum.com/threads/idle-issues.468/
I'm assuming he means 30-40 degrees outside temp.
I would start with cleaning the IAC. Quick and easy. There is a write up in the how to's here if you don't know how to do that.
Updates? Curious to hear if anything worked out in this case?
Also on a side note...Bainbridge Island, man i'm jealous. Great area!
X2, your idle issue sounds very much like it could be caused by nothing more than a dirty IAC. IACs don't usually need to be replaced, they can normally be restored to 100% operating condition by simply cleaning them.
If your engine isn't warming up enough, the wrong/too low of a temperature thermostat might have been installed by a clueless previous owner or mechanic. The thermostat must have a 195 degree temperature rating, don't use 160-185 temperature thermostats. Avoid too the use of any thermostat that is a "fail-safe" which only means it likes to fail in the open position. A Stant SuperStat 195 degree thermostat is a great choice.
Idles while moving at a good 600 rpm but drops to a rough 500 when fully stopped. I have cleaned my IAC, put a new mopar IAC senor in as well, and new mopar TPS. Any suggestions on what else could cause the rough idle?
2003 Sahara — 94,000 mi
Side note: Theres no exhaust leak, also is it true that an bad O2 sensor can also cause a low idle?
Vacuum leaks.
Try spraying carb cleaner around the vacuum lines.
Also be aware there is a line by the battery that Ts...one side into the HVAC box and the other down to a vacuum reservoir.
Thanks, ill do that and give an update.
I forgot to mention the rpms drop to 200 ish and jeep starts to stall as soon as steering is full locked, but thats probably another issue. Just thought id put it in here.
