05Rubicon
Upgraded my instrument cluster with a new faceplate (that can be seen in the daylight).
I ran tsl swamper radials on my cj5. With lockers front and rear it was damn near unstoppable.1.25" BL, 1" motor mount lift, and 34x10.50 Interco LTB's. They ride better than my BFGs did, and so much grip! All ya'll need swampers. Just do it.
Return to center can be affected by caster angle. To much slows the response.Replaced my steering gear. The old one was leaking and I was getting poor return to center. This is a reman Lares 1353 from Rockauto, I couldn’t find a lot of reviews or comments on it, so I’ll give it some time and give my impressions after some miles. Initially, all is well.
However, return to center improved only slightly, so I think there is still something else going on there.
Return to center is directly affected by steering geometry. (Toe in, caster, and camber) primarily caster and toe on a jeep because camber is fixed. the more positive the caster the more return to center. The only adjustment that is easily changed on the TJ is toe. Caster is minutely adjustable (directly relating to pinion angle) without offset ball joints. If your camber is way off something is very bent or worn out. Toe out will also tend to make your Jeep want to wander a little more than it should. Toe in will tend to do the opposite but too much will chew your tires up in short order.Replaced my steering gear. The old one was leaking and I was getting poor return to center. This is a reman Lares 1353 from Rockauto, I couldn’t find a lot of reviews or comments on it, so I’ll give it some time and give my impressions after some miles. Initially, all is well.
Re
I have another thread running specifically for my return to center issues and I get into the alignment over there. https://wranglertjforum.com/threads/return-to-center-advice.27485/Return to center is directly affected by steering geometry. (Toe in, caster, and camber) primarily caster and toe on a jeep because camber is fixed. the more positive the caster the more return to center. The only adjustment that is easily changed on the TJ is toe. Caster is minutely adjustable (directly relating to pinion angle) without offset ball joints. If your camber is way off something is very bent or worn out. Toe out will also tend to make your Jeep want to wander a little more than it should. Toe in will tend to do the opposite but too much will chew your tires up in short order.
Installed a Sound Ordnance B-8PTD powered sub in place of the stock joke. Won't knock you out of your seat but it definitely fills in the low end. As per a subwoofer thread on this forum, I followed what others have done and mounted the remote gain in the center console. I also remounted the tray from a bottom mount position to a top mount position to get the extra height needed. I used a 30a circuit breaker instead of an inline fuse on the primary wire and used the remote power wire from the head unit to power on with the stereo. View attachment 125248View attachment 125249View attachment 125250View attachment 125251View attachment 125252View attachment 125253
I also installed a Rugged Ridge dash multi-mount with phone holder. Pretty straightforward install.View attachment 125254
I still need to upgrade the dash and sound bar speakers.
I'm assuming yours didn't come with the factory sub. The liner, as you reference it, is much shallower to make room for the sub. You would have to find a console with the shallow liner. The liner is riveted in place so I drilled them out then set the liner in from the top, redrilled the holes to 1/4" and used plastic automotive trim rivets. The sub I used just fits front to back so it won't really move that way. I used some Velcro to hold it in place on the tranny hump so it stays against the grille in the console. If you look closely at the pic you can see the gray reference marks I made to set it in place. I got my measurements by dry fitting in the console itself.This is exactly what I've been looking to do; I have a tube sub from my old Cherokee in the back but it just takes up too much room. Do you have a link to a write up? I have an 02, so the grill is there in the center console but the actual liner goes all the way down, what'd you use to to remount the tray to gain the clearance? Also, how is the sub actually attached in there?
I ended up breaking one of the bottom bolts. Had to drill and retap.Waited for the matching Bestop rear seat cover to my front seats to show up on Amazon Warehouse and they finally did the other day so I had to jump on them.
Also started the rear bumper and tow hitch removal in preparation to install the new Bestop high rock rear bumper which is scheduled to arrive tomorrow. It’s putting up a good fight. Got all the bolts out except the two bottom bolts. I think they’re probably rusted in there pretty good. Soaking them in PB blaster overnight and I’ll try again tomorrow hopefully without breaking a bolt
Ugh. Hoping to avoid all that. Having flashbacks of the rear upper shock bolts. The passenger side bolt is especially annoying because the damn exhaust pipe is in the way too. Right under the bolt.I ended up breaking one of the bottom bolts. Had to drill and retap.
Ya, uh I have dual exhaust exiting in front of rear tires so I didn't have that issue.Ugh. Hoping to avoid all that. Having flashbacks of the rear upper shock bolts. The passenger side bolt is especially annoying because the damn exhaust pipe is in the way too. Right under the bolt.
Damn. NiceInstalled a Sound Ordnance B-8PTD powered sub in place of the stock joke. Won't knock you out of your seat but it definitely fills in the low end. As per a subwoofer thread on this forum, I followed what others have done and mounted the remote gain in the center console. I also remounted the tray from a bottom mount position to a top mount position to get the extra height needed. I used a 30a circuit breaker instead of an inline fuse on the primary wire and used the remote power wire from the head unit to power on with the stereo. View attachment 125248View attachment 125249View attachment 125250View attachment 125251View attachment 125252View attachment 125253
This past week I added the Rampage grille insert. A much better look!View attachment 125240
