I've been running Zone off road's sway bar links for the past 5 or 6 years. Big advantage is that it does away with the OEM ball joints and uses a bracket instead. Bushings are replaceable and they're cake to install.
A year ago I notice a weird little 'chirp' every once in a while when pulling away from a stop. When putting on the lift last weekend, I noticed why. The head of the bolt that holds the sway bar link bracket in place was rubbing against the frame ever so slightly.
Then, looking at the sway bar itslef, I noticed it's not centered. On the passenger side, there's about a 2" gap between the sway bar and the frame. On the driver's side it's maybe within 1/4" of the frame.
Maybe that's how it's supposed to be, but it doesn't seem right. It seems like that sway bar should be centered somehow, but I can't figure out how. That little 'chirp' is starting to drive me nuts. Like water torture.
