Loosened the radiator and condenser and was able to get the cooler into the grill. Everything is now installed, but ran into a minor snag. In following the picture below, the '97 to '02 line out of the gear box is 3/8" hose. It's supposed to go to the cooler, which has an -8 AN fitting that uses 1/2" hose. Likewise, the line that comes out of the cooler, going back to the reservoir, is 1/2". However, the fitting on the reservoir accepts 3/8" hose.
Based on what I'm seeing, I need to put two 3/8" to 1/2" reducers inline. One on the return line coming out of the gearbox, going to the cooler, and one on the line leaving the cooler and going back to the reservoir. Or, are there fittings that can be installed in the gearbox and reservoir that can just accept 1/2" hose?
