In my '03 5 spd Rubi, with B&M short shifter by PO, doesn't have any spring action to center stick in neutral. Is this typical or is something amiss.
Thanks guys.
Thanks guys.
Thanks Chris. Any thoughts what to look for? Shifts smoothly, quiet, fluid level good and looks clean.No spring is needed, it should always return to center.
Thanks WallyWestUsually that's caused by the little plastic connectors that hook the cables to the shifter. Sorry, don't know all the technical terms. There are two cables, one for front to back motion, and one for side to side. For such a critical part they tend to be real flimsy. There's no spring in the shifter itself, if one or both those plastic connectors is cracked or broken the shifter will just flop around like a dead fish. Real fun when that happens while driving.
If they look fine, spray some WD 40 or whatever on both ends of the linkage cables, and look into replacing the bushings, they can also cause that issue.
Thank you ChrisI'm not entirely sure. My experience with manual transmissions is that the transmission itself always returns the shifter to the center position. However, I'm not sure what's inside of it that causes this.
That is somewhat the case with the AX15 but on the NV3550 I can tell you that the return to center action is from the shifter housing only. I've had an issue with stock shifter recently on my 03 Rubi.Also, I checked with B&M, they said any centering action is by transmission not by shifter itself
On the NV3550, if the bushings in the shifter tower are missing or worn down the shifter will be floppy. Check out the thread I made a while ago, it has a video. On the AX15 the centering mechanism is in the trans, right below the shifter tower. I am 90% sure of that because I have a spare AX15 in my garage at the moment.The shift forks do the centering from pressure applied to them from the gears and/or springs on the shift rail. Only time I've not seen some sort of centering action is on a manual 3 speed. It has only two shift rails.
Take the tower shifter off and open it up to inspect it. One of the two plastic bushings might be worn out.along similar lines my NV3550 sometimes gets stuck and doesn't want to return to center. If I jiggle it a bit it frees up and starts working again. Think that's something in the shift tower messing up? I can feel and hear it click, it almost feels like a spring or something that gets out of whack.
Hope bushings aren't missing or worn, truck <75k miles and shifter is newer yetOn the NV3550, if the bushings in the shifter tower are missing or worn down the shifter will be floppy. Check out the thread I made a while ago, it has a video. On the AX15 the centering mechanism is in the trans, right below the shifter tower. I am 90% sure of that because I have a spare AX15 in my garage at the moment.
