Got some factory mopar style switches to blend into the dash for the air compressor and the rear Yukon Air Locker. Like the way it turned out because I did not want to cut into this dash...love the factory look and its really clean and not obvious. I temp mounted the air compressor to the 2 steel loop tie downs on the passenger side in the cargo compartment. Works well and keeps the underneath clean and thankfully in the LJ I have room to do this without compromising too much storage space. If I ever have to remove for any reason I can cut the plastic tie straps and remove it and then put it back.
