I topped up the reservoir about 4 weeks ago and I noticed today that it’s almost empty?? Oil is good looking. I have no leaks At all at the hoses or rad etc. Where the hell is the coolant going??
X2If you're 100% certain it isn't in the oil and the engine isn't burning coolant, then there is always a chance that your cooling system itself was low, and the coolant has gone into the cooling system to fill the empty space.
I'd fill it again and see what happens.
A blown head gasket is the only other explanation if there are no external leaks, assuming you also ruled out your heater core.It’s not a blown head gasket.
Common spot. If the clamp isn't on there just right....
That hose looks old and a little too short, I would replace it and the lower if it looks as bad, also the recommended hose clamp is the OEM style.
I’m going to check the tension to those clamps tomorrow. About 2 months ago I noticed leakage coming from my lower rad hose and the clamp was just loose. I replaced those hoses and radiator 8-9 months ago ....I can’t remember if I filled the reservoir entirely after bleeding the system lol maybe the coolant just filled up the system ....LOL. I hate those clamps tho ...every time I replace something with those on I don’t put them back they’re such a bitch to get on and offI had leaks from various hoses with worm clamps when the weather is back and forth warm/cold like in the fall and spring, every season for the last couple years. Back in November I redid my entire cooling system and went back to the constant tension clamps and haven't had a leak yet.
Amazon can hook you up for $11.00I’m not a fan of those unfortunately lol I know they’re top notch but I can’t for the life of me get them on and off
Hose Clamp Pliers Auto Repair Tool Swivel Flat Band for Removal and Installation of Ring-Type or Flat-Band Hose Clamps https://www.amazon.com/dp/B07CR6BN2Y/?tag=wranglerorg-20
HahahahaAmazon can hook you up for $11.00
