505 Performance for the 2.5
StG58
TJ Guru
On the road.
I was out looking for 2.5 liter parts and stumbled across this company out of New Mexico. 505 Performance. Turbo's, Heads, Short and Long Block stroker motors, Pistons, Roller Cams, Roller Rockers... All the old school stuff that I grew up with.
http://www.505performance.com/
There's a 2.9 liter stroker kit that puts out a reported 190HP and 200 ft/#s torque. $3,000 in a crate.
Interesting stuff...
Let's think about this... $3000 for an engine that puts out 190 hp? You can get a brand new crate 4.0 for less than that, haha!
I don't have to tell you this, you already know.
But while we're on the subject, I've heard 505 Performance is absolutely horrible to deal with. All I read about them is bad stuff.
Reactions: Bird and StG58
I know nothing about them. I just ran across them after contributing to another thread about mods for the 2.5. I was cruising the interwebs refreshing my 2.5 knowledge and ran across their site. Their warranty language is really iffy.
Cracks me up though. For $3000 you can almost reach the stock power levels of the 4.0. And blow your AX5 all over the trail at the first opportunity.
I did run across an interesting set of posts on another site where a guy did all of the normal mods to his 2.5. The interesting observation that he had was that after each mod, the ECM compensated for the mod and he ended up right back where he started. He probably put as much into mods for his 2.5 as that crate motor costs and ended up taking them all off. He was using a long, uphill on-ramp as his performance baseline. He ran the ramp after each mod and timed how long it took him to get on the highway and noted top speed. Interesting results, in that after about a week to ten days his final merge speed and the time is took to run the ramp came back to where he was in stock trim. The only thing he managed to accomplish was a reduction in gas mileage.
I really need to write up a comprehensive post on 2.5 performance. Maybe I can help someone else not try to reinvent a very expensive wheel.
The only things that are proven to increase performance in an SE have nothing to do with the engine. Gears and a diet. That's it. Or an engine swap!
Reactions: Bird
As you and I both know, upgrading the 2.5 to get more "power" out of it is pointless.
If you're really concerned about power you should either:
A) Sell it and get a 4.0
B) Sell it and get an entirely different vehicle
C) Do a V8 swap
I see these guys who do things like throttle body spacers (snake oil), air intakes, exhaust, etc., thinking that somehow they're going to transform their 2.5. Sorry, it's not going to work. You've got a smaller engine, a heavy vehicle, and the aerodynamics of a barn. Throw those all together and it's never going to be "fast".
However, I'll bet if you took that 2.5 and put it in a vehicle half the weight and with better aerodynamics, then it would be plenty quick!
Reactions: StG58
What about FI? Wrong torque curve?
There is no realistic FI solution for the 4 cylinder Wranglers. This has to do with the fact that there is no engine management system such as the Split Second fuel controller (with the 7th injector) for the 4.0 engines.
That being said, if you did install a turbo or supercharger to your 4 banger, the only real way of controlling the fuel (and therefore making it so your engine doesn't explode) would be a standalone system such as Megasquirt. The problem with that is that a standalone system takes a ton of work to get setup correctly (i.e. dyno tuning, etc.). By the time you had put the supercharger on, the standalone system, and everything else, I would bet dollars to donuts you'd be into it for 5-6k (if you count your time as being worth anything too).
At that price point, the smart thing to do would be sell it and get a 4.0, or do a V8 swap.
Reactions: PhantomX and StG58
Writing a 2.5 "hot rodding" thread as we speak. I cover most of this and more in it.
The only way to increase performance with a 2.5 is gears and weight reduction. That's it. Everything else is pointless and a waste of perfectly good money that could / should be spent on gas and maintenance to learn how to drive the 2.5 off road.
The SE absolutely rocks within it's performance envelope.
Here's part of it:
TJ SE's and the 2.5 liter engine
There's a lot of discussion around the Jeep 2.5 liter engine and how to increase horse power and torque.
The short answer is, you can't. No one likes that answer, but it's the truth. The 2.5 is what it is. There are a lot of reasons to purchase an SE. Lighter weight, lower purchase price, successfully burns anything that looks and smells like regular pump gas, simpler and slightly less expensive to maintain are among of them. Oh, and they last bloody forever!
The common modifications that are attempted to gain performance are:
4.0 Throttle body
Throttle body spacer
Cold air induction
High flow air filters
IAC sensor relocation
Ford yellow top, 4 hole injectors
Headers
Cat back exhaust system
Power chips
Electric fans
Some of the less common modifications are:
Roller rockers
High performance cams
Ported and polished heads
Stroker kits
Turbocharging
Wet shot nitrous injection
Let's start with the common modifications first.
Intake modifications:
The TJ SE intake system is designed, and comes from the factory, to flow more air than the 2.5 liter engine needs to produce maximum HP and torque at wide open throttle and maximum load. True fact. There are no meaningful restrictions to air flow. The engineers did a good job of designing the intake system from the start. The only way to get additional air and fuel into the combustion chambers is to put a cam with higher lift and / or longer duration in, bigger intake valves, some form of forced air induction or a wet shot nitrous system on the engine.
Putting a 4.0 throttle body on will give me an extra 10 HP, right? Nope, sorry. Even with port matching the TB to the intake manifold, all you are gaining is the potential to flow more air. The 2.5 is really only an exotic air pump. The head will only flow so much air, and that amount is the air required to fill the combustion chambers at bottom dead center. That is especially true at lower RPMs, where our TJ SE's normally operate on the trail.
Putting a throttle body spacer in has got to improve performance, right? Nope, with the port injection there are no gains to be had with increasing plenum volume with a throttle body spacer. This is especially true of the magic throttle body spacers that promise miracle gains from swirling the intake air. That trick is a left over from the days of carburetors, and even then it wasn't effective. The length of the intake runners and the plenum volume needs to be matched to the engine's displacement, HP and torque bands. The Jeep engineers did that already. No gain to be had there.
Cold air induction has got to give me something, right? After all, cold air is denser than warm air! This is a true statement, as far as it goes. BUT, the difference in air temperature and air density going into the engine with a cold air induction system compared to the stock system is minimal at best. I have never seen or heard of a temperature difference greater than about 10 to 15 degrees F between a cold air system and the stock system. Most of the time the temperature difference is lower than that. The engine realistically doesn't see a difference and any power gains are unnoticeable.
High flow air filters will get more air into my engine, right? Sorry, the stock paper element and air box flow as much air as the engine needs. It also does a much better job of filtering the intake air than any of the aftermarket air filters. It's cheaper as well, and readily available.
So, how about relocating my IAC sensor to the air box? Again, this is only going to show a difference of a few degrees in temperature between the relocated position and the stock position. Once the engine reaches operating temperature and the ECM goes into closed loop mode, the O2 sensor takes over anyway as the ECM controls the air fuel mixture at 14.something to 1. No gains to be had there.
High flow four hole fuel injectors are the clear ticket, right? More fuel = more power! Not going to happen, sorry. Once the engine warms up and the ECM goes into closed loop operation, the amount of fuel injected is based off of the signal from the O2 sensor. The ECM will maintain that roughly 14/1 ratio no matter how much the injectors will potentially flow.
Now about the exhaust system:
Headers will give me more power! Uh, no. The TJ SE exhaust system is not restrictive. It will easily flow all of the exhaust gasses that the 2.5 will generate. The only thing you will gain is noise. And probably exhaust leaks from gasket mis-matches and failures. Headers will also put more heat into your engine compartment. The chances of the tube diameter and tube length matching the power band are also probably lower than the stock cast header.
Cat back exhaust systems are the cat's meow for performance gains. Not really. The Jeep engineers designed the exhaust system to flow the right amount of exhaust and generate the correct amount of back pressure for the 2.5. You can over scavenge the cylinders and kill performance and gas mileage with an ill designed exhaust system.
What about an electric fan? Let's get rid of all that parasitic drag! All the new cars have them. There are reasons to have an electric fan, but for the most part, no. It takes X amount of energy to move Y amount of air through the radiator to keep the 2.5 engine properly cooled. The stock fan does a good job of that, and doesn't generate a ton of parasitic loss at normal speeds. That's what the fan viscous coupling does. There's just not enough gain there to make it worthwhile.
A power chips will rock my 2.5! Nope, not really. You're already getting optimal air flow and the correct fuel mixture. Any gains from additional spark advance are minimal at best and will restrict the octain requirements for the 2.5.
Still working on this...I'll add more later and get through the list!
So, basically, the only way to get any gains out of a 2.5L is to replace it. How bout one of them little 1.3L Ecoboost direct injected little critters? 200hp and less weight. I wouldn't be surprised to see an upcoming JL with one of them little 4 bangers.
Reactions: StG58
Yup, or spend a ton of money for marginal gains. When you start getting into the mods that actually generate more power and torque, the costs skyrocket and the mods push the power and torque bands out of the range that are usable off road.
If you're going to plug an Ecoboost in, why not a V8? Way more power and better economy than the 2.5 to boot. At 200 HP, you may as well have an X or a Sport.
Here's part of it:
4.0 Throttle body
Cold air induction
Headers
Power chips
Electric fans
Roller rockers
Stroker kits
CPS modifications
Turbocharging
I'll sticky this once it's done! I look forward to reading it.
Reactions: StG58
The new JL comes with a few options as I understand:
A V6 Pentstar
A 3.0 Tubo EcoDiesel
Some sort of 4 cylinder turbo
Now we're getting into the more old school hot rodding tricks for generating more power out of the 2.5. Forced air induction, displacement changes, compression ratio increases, that sort of things. These will increase power, but the cost goes through the roof quickly.
Let's step back a moment and talk about what generates power. Power comes from burning a specific amount of gasoline and air at a specific ratio. We are starting out with 2.5 liters of displacement. That's not a lot of air / fuel being burned in the grand scheme of things, and it will only generate so much power.
We can increase the amount of power generated by increasing the compression ratio and by extension the efficiency of the engine. Doing so increases the octane rating required to prevent detonation and the destruction of the engine. One of the bonuses of the 2.5 is that it will happily burn anything that looks and smells like gasoline. So we may not want to go there.
Another way to increase efficiency is to eliminate as much parasitic drag in the engine as we can. We can try to make as much power go to the transmission as possible. One of the ways to do that is with roller cams and roller rockers. With a four banger, that is a loosing proposition because there really isn't enough parasitic loss there to justify the expense. A full roller valve train would be expensive and result in an almost unnoticeable gain.
We can balance and blueprint the engine, so that it operates closer to it's theoretical efficiency. Again, that's a lot of expense for not a lot of gain. I estimate that you are only going to gain 15 - 20 HP at the top end with both a roller valve train and a balanced and blueprinted engine. And you'll only see that gain in the higher RPM ranges.
What about camming the engine? There's the possibility of gaining a little here, but we want a nice, flat HP and torque curve for the way we end up using the 2.5. Going with a lot of duration and overlap on the cam generates HP, but the power curve move up in the RPM range. Not what we are looking for. What about higher lift on the cam? We can get some gains there, and it can be done with rocker arms of a longer ratio. The longest rocker arms that will fit under the valve cover are approximately 1.6 to 1. We also have to be careful to not drive a valve into a piston doing this. Especially if you rev it and float a valve. Bang, engine and head rebuild.
How about a stroker engine? That increases the amount of fuel / air mixture being burned and generates more power! Yup, it sure does. I've seen 2.5 stoker engines go for $3000 and up. That puts you in the same HP and torque range as a stock 4.0. That's a lot of money to turn an SE into a stock Sport or X. If you can pick up an SE for $7000 and add in $3000 for a stroker, you're not far off from a decent Sport or X. Plus you still have the AX5 to deal with in the SE. It does solve the riddle of how to burn more fuel / air.
There's always head modifications as well. These work best in conjunction with a high lift and long duration cam. It will get more fuel / air mixture into the combustion chamber, but you'll only see the increase at higher RPM's. You can do things like bigger valves, CC'ing the heads so that all four combustion chambers are as close to the same size as possible, polishing the combustion chambers, raising the intake ports and port matching, contouring the intake valve bowl, lots of tricks to tried there. My take is that there just isn't enough displacement in the 2.5 to really make any of this worthwhile at the lower RPM ranges.
Forced air induction. Now this works. More fuel / air into the engine = more power. My preference would be something like a roots type positive displacement blower. It would generate power from idle to wherever you lifted the throttle. With supercharging and turbocharging the 2.5, you are faced with replacing the ECM with something that would control spark and fuel management. It's out there and available, but man is it expensive and hard to find. Plus you need to program these controllers from scratch to match your engine parameters. It's a good way to end up buying another 2.5. Good thing 2.5's are cheap!
Wet shot nitrous injection. This technology has been around since WWII, but it has nothing to recommend it to an SE owner. Just don't.
